Flashjet Posted April 24, 2005 Share Posted April 24, 2005 I am kinda cheating here. This is for my wife's car which is not a Lexus. But you guys seem to know everything to do about cars so..... The lens on the headlights are plastic and have clouded and are nolonger clear. I have tried buffing them clear which seems to help for just a day or so and then they are cloudy again. Is there something that can be done to clear off the cloudiness and regain the glass clear lens as when it was new and keeps it clear? Thanks in advance, Flashjet Quote Link to comment Share on other sites More sharing options...
ford212.809 Posted April 24, 2005 Share Posted April 24, 2005 Go to the search box in THIS forum and type in "lens" or "headlight" - you will find your answer fairly quickly. ;) Quote Link to comment Share on other sites More sharing options...
TOGWT Posted April 25, 2005 Share Posted April 25, 2005 Removing Oxidation or scratches from Vehicle headlights, Brake lights (polycarbonate): Most vehicles now have a protective, transparent, plastic lens covering the headlights to protect expensive lamps (headlight assemblies range from 500-$700+) from flying stones and road debris. They discolour over time, becoming opaque and cloudy; these lenses can severely restrict the amount of light reaching the road. The lens has a silicone-based coating applied to its outer surface, some manufacturers apply two different types of coatings to the outer surface of the lens, these coatings are mainly for UVR protection, but are also for impact and abrasion resistance, once the coating (s) fail the lens surface will occlude (clouding or yellowing) While most of the cloudiness is on the surface, severely discoloured lens cannot be brought back to optical clarity. If you live in a southern state, this discoloration can become noticeable in as little as two-years Application Methodology: ·Use a solvent type cleaner (Klasse All-In-One) if this does not remove the oxidation use a plastic polish · Meguiar’s PlastX contains a microscopic diminishing abrasive, which requires a little pressure when applying it to enable these abrasives to remove the discoloured plastic and expose new plastic. Or Renovo Plastic Cleaner ·Plastic Cleaners can be used to clean and condition Perspex as well as flexible plastic but is not suitable for use on glass. ·Prior to application of a plastic polish ensure that the window is clean and free from dust particles by washing with a soft cloth and warm water. ·It is not advisable to use cleaning detergents on plastic. ·Shake the bottle thoroughly. Plastic polish can be hand or machine applied ·Using a random orbital buffer with a 3.5-inch backing plate and a 4-inch (LC White) polishing pad or a terry cloth applicator ·Place a small dab (about ½-inch diameter) of plastic polish on the foam pad or applicator. ·Place the pad on the lens surface and turn on the machine (speed #4) ·Polish the lens repeatedly in a left-to-right and an up and down pattern. ·Continue polishing until all the polish is gone ·Wipe the lens with a damp Microfiber towel ·Inspect the lens, repeat the polishing process 2-3 times as necessary ·Plastic polish will not remove clarity defects that are within the plastic but it will remove external/surface scratching and oxidation (yellowing JonM Quote Link to comment Share on other sites More sharing options...
mailman Posted April 26, 2005 Share Posted April 26, 2005 I used Brasso(metal cleaner) as advised from an old post.Rubbed it on good with an applicator pad then buffed it off good with a microfiber towel.Repeated the process 3 times.They came out looking pretty, like new.Now all I have to do is use some Sprayway (ammonia free) glass cleaner and they stay PRETTY. Quote Link to comment Share on other sites More sharing options...
