Hello,
I just stop by to rotate and balance my tires. and i find out that one wheel is bent.
Please help me to make Decision: should I just buy one used wheel($100) or go and buy all four new wheels? if you think that i should buy all four new then i have to buy 15" wheels, because i just changed all four michelin tires.
Which one is good looking and looks perfect on Lexus?
Need help.
Thanks,
Get a second opinion on that wheel. Go somewhere else to get them balanced. Don't say anything to the second opinion place. Sometimes these low payed techs set up the balancer wrong. I have been through this a time or two. B)
Hello,
You have very good thought.but I don't want to write to long so i didn't mention, Yes first i went to sears and then i went to discount tires. Both informed me same results.
Thanks,
Hello,
Need help.
Thanks,
You mention one of your wheels is bent, can you post a pic of what the wheel looks like? :unsure: Are these the 'factory original' wheels on your car or aftermarket?
:cheers:
Hello,
these are 'factory original' wheels.
Its looks good but when they put for balancing ,looking side of the machine you can see up-down rotation.
Thanks,
Hello,
Thanks,
I have an idea for you......why not check your spare tire in the trunk? It should be a 'full size' rim (the exact same as you have on now)...have a look & there is the solution to your problem ;) Is the bent rim safe for a spare? just swap them. B)
:cheers:
That's regular full size steel wheel.
It's don't match.
I called junk yard he has it and can sell it for $100.
I am thinking to get it. and leave bad for spare.
Thanks,
It's don't match.
Thanks,
The current spare wheel in the trunk does not match the other wheels on the car? I thought they were factory originals? :unsure: But $100 at an auto wrecker or salvage yard is not a bad price if the wheel is in good condition. B)
:cheers:
I got it.
Sears checked it. Perfect condition.
Job has been done.
Thanks to everyone for their inputs.
Sears guy was telling me that other little bent i cann't put it in truck.
Bolts not fit. Something?
Why?
I got it.
Job has been done.
Why?
Funny, I work for Sears Canada actually in I.T. lol :lol: B)
Just play with the wheel & if your patient, it should fit in there no problem.
Glad you got your problem solved.......happy to help! ;)
:cheers:
Hello,
It's good to hear that you work for Sears because those are the people who discovered that the wheel was bent.
What he was saying was that the alloy wheel is higher then the spare steel wheel (full size) and you can't put the bolt on top of it so the wheel can stay in place without making noises. But as you adviced I will check on it patiently.
Thank you very much
