justin97 Posted April 15, 2005 Posted April 15, 2005 ok i have a set of d2r bulbs, ballasts , and inginors. also i have a set of h7 adaptors, but does any one know if a the stock wiring, and relays are enough to handle the strain of hid? the wiring it is 16 gauge right? btw the car is a 1997 es300
mburnickas Posted April 15, 2005 Posted April 15, 2005 ok i have a set of d2r bulbs, ballasts , and inginors. also i have a set of h7 adaptors, but does any one know if a the stock wiring, and relays are enough to handle the strain of hid? the wiring it is 16 gauge right? btw the car is a 1997 es300 ← you will be fine. I had phillips on my 98
SKperformance Posted April 16, 2005 Posted April 16, 2005 It is ok but the ballast are more reliable by having a direct set of wiring to the battery with a relay to turn on.
