Bourne33065 Posted April 15, 2005 Share Posted April 15, 2005 Hi, I have a 93' SC400, and I was wondering how do I realign my water jets (the ones that clean the windshield)? The furthest left wasn't working at all, and then I just poked at the hole, and now it works but just sputters a little, and sometimes it works perfect. So I was wondering if any of you know how to fix them, or realign them, some tips would be GREAT!!!! Thanks!! Quote Link to comment Share on other sites More sharing options...
Labtec Posted April 15, 2005 Share Posted April 15, 2005 i have the same problem with my '92 400. They used to work just fine. Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted April 15, 2005 Share Posted April 15, 2005 I have heard you can slip a credit card under the front and back of the washer and pop it off. I would then disconnect the hose and soak the jets in vinegar to dissolve the crud. Quote Link to comment Share on other sites More sharing options...
Sluggo Posted April 15, 2005 Share Posted April 15, 2005 I was going to suggest vinegar as well. Maybe you could just fill the reservoir with vinegar (it's real cheap) and pump it through? Keep a towel over the jets so as not to spray your paint job - the vinegar won't hurt it but the schmutz it cleans out might. Quote Link to comment Share on other sites More sharing options...
axis8758 Posted April 15, 2005 Share Posted April 15, 2005 Or another idea is to use jets from a newer model Lexus. Quote Link to comment Share on other sites More sharing options...
bean_8044 Posted April 15, 2005 Share Posted April 15, 2005 Or just put a needle in the nozzle. Not very far in, at most 1/8 inch. With the needle in, you should be able to redirect the nozzles also Quote Link to comment Share on other sites More sharing options...
