I am in the process of pulling out the rear wheel bearings in my 92 with 268k on it. However, i'm not exactly sure what i need to relpace them. So far I have found just the bearing, as well as the bearing assembly. It seems as if they may be split between vehicles with and without ABS, but i'm not sure. The lexus dealer said all they had available was the hub and bearing assembly. I have no idea what part to order at this point, can anyone help me here?
ABS is only an option on a camry so it should be standard
you have to buy a new hub and a new abs sesnor as well as it will fal apart if you try and remove it
