ranger2692 Posted March 8, 2005 Share Posted March 8, 2005 I took delivery on a 2005 LS430 about 3 weeks ago, and have checked high and low in the owners manual on how you "Remove" Icons in the Nav Display such as Gas Stations , ATMs etc?? I found an area in "Setup on the diaplay" which on page 3 shows "Change POI Icons" but when I click on it, it dosen't give optionm to remove only add! Can Anyone give a step by step or page number in manual on how to do this?? I even tryed to do it thru the voice system and wound up putting more catagories on the display?? Thanks Ben Quote Link to comment Share on other sites More sharing options...
SW03ES Posted March 9, 2005 Share Posted March 9, 2005 If you hit "POI" on the base of the screen while its in map mode you can activate and deactivate the POI icons. Quote Link to comment Share on other sites More sharing options...
ranger2692 Posted March 9, 2005 Author Share Posted March 9, 2005 I took delivery on a 2005 LS430 about 3 weeks ago, and have checked high and low in the owners manual on how you "Remove" Icons in the Nav Display such as Gas Stations , ATMs etc?? I found an area in "Setup on the diaplay" which on page 3 shows "Change POI Icons" but when I click on it, it dosen't give optionm to remove only add! Can Anyone give a step by step or page number in manual on how to do this?? I even tryed to do it thru the voice system and wound up putting more catagories on the display?? Thanks Ben ← Quote Link to comment Share on other sites More sharing options...
ranger2692 Posted March 9, 2005 Author Share Posted March 9, 2005 If you hit "POI" on the base of the screen while its in map mode you can activate and deactivate the POI icons. ← Ranger2692 9 mar 05 14:00 hrs Wouldn't that option (POI = OFF) turn off all Icons?? If so, what I am actually trying to do is remove certain Icons from the screen that are currently showing" It seems that it has to be done through Menu, then Setup, and then the area that says "Show POI Icons" but when I press Change I don't see option to REMOVE" Any suggestions??? Thanks for your reply. Ben Quote Link to comment Share on other sites More sharing options...
leot Posted March 9, 2005 Share Posted March 9, 2005 If you hit "POI" on the base of the screen while its in map mode you can activate and deactivate the POI icons. ← Ranger2692 9 mar 05 14:00 hrs Wouldn't that option (POI = OFF) turn off all Icons?? If so, what I am actually trying to do is remove certain Icons from the screen that are currently showing" It seems that it has to be done through Menu, then Setup, and then the area that says "Show POI Icons" but when I press Change I don't see option to REMOVE" Any suggestions??? Thanks for your reply. Ben ← Quote Link to comment Share on other sites More sharing options...
leot Posted March 9, 2005 Share Posted March 9, 2005 If you hit "POI" on the base of the screen while its in map mode you can activate and deactivate the POI icons. ← Ranger2692 9 mar 05 14:00 hrs Wouldn't that option (POI = OFF) turn off all Icons?? If so, what I am actually trying to do is remove certain Icons from the screen that are currently showing" It seems that it has to be done through Menu, then Setup, and then the area that says "Show POI Icons" but when I press Change I don't see option to REMOVE" Any suggestions??? Thanks for your reply. Ben ← ← If I understand you correctly, you want to remove (for instance) some but not all icons, like some gas stations: if so, you can't do it; you can however, zoom in and get only icons for that map area. leot Quote Link to comment Share on other sites More sharing options...
