I recently installed the 97+ tail light conversion with the 97+ tail lamp failure module and I know this is supposed to fix the tail light indicator from coming on due to the conversion and still be operational...but my turn signals are hyper flashing which I thought the tail lamp failure module was supposed to correct also? Has anyone had the same result?
Check for any bad bulbs.
No bad bulbs all flashers work. If my parking lights and side marker lights are out could this make my turn signals flash really fast? Also, with the parking lights and side marker lights out could this trigger the tail light bulb indicator light to come on?
I'm not 100% sure, but if you have ANY bulbs out then you should replace them. That may fix the problem. If it doesnt then you'll need to contact the place you bought the module from as it may be defective.
