robshort Posted June 22, 2003 Posted June 22, 2003 Hi, has anyone experienced the shifter not being able to move due to the brake lights not working in a 93 GS 300. It is not a fuse so I dont know what is causing the brake lights to work sporadically. Please let me know if anyone can help with this problem Rob
steviej Posted June 22, 2003 Posted June 22, 2003 possilby the brake release switch. There is a switch that is activated when you step on the brake to take the shift lever out of park. Maybe this has crapped out. I think this is tied into the brake light switch. Can you shift using the manual override? steviej
robshort Posted June 22, 2003 Author Posted June 22, 2003 Hey Steviej, Thanks for the help, I am not sure about how to use the manual override. That sounds like a good start, is this a part available anywhere or is it just a dealer part. Would you know how easy it is to install? Thanks again, Rob
