kshgl87 Posted February 23, 2005 Share Posted February 23, 2005 I have a 91 ls400 w/ 145k miles and it seems like something in my front suspension is making noise like a squeak. I really dont know a ton about suspension but anyways whenever i leave my driveway and the front drops down the sloped curb i can hear a loud squeak, this also happens when i hit large dips or inclines in the road. Can anyone help me out and tell me what this is, its not a huge deal I'd just like to find out what it is and maybe fix it. thanx Quote Link to comment Share on other sites More sharing options...
nc211 Posted February 23, 2005 Share Posted February 23, 2005 i'm dealing with the same thing on my 95 with 95k miles on it. I've replaced the front strut rods and lower ball joints in hoping to kill that noise. Do you have vibration issues up front as well? For me, I'm thinking it's the shocks in general that are shot. The car feels more and more like a boat these days. Quote Link to comment Share on other sites More sharing options...
silvermate Posted February 23, 2005 Share Posted February 23, 2005 your bushings are worn, or shot......very common problem, and relatively cheap to fix...especially if you diy Quote Link to comment Share on other sites More sharing options...
Econ Posted February 23, 2005 Share Posted February 23, 2005 +1 on that. In regards to expense, it depends on which control arm is having the problem, but usually lower control arms squeak and upper control arms clunk (not always). Of course, cheap is relative as well - with lower control arms coming in at ~$200 and uppers ~$300 depending on your source. I haven't found anyplace that sells replacement bushings yet. Replacing only the bushings would require a machine shop to press out the old and press in the new. Quote Link to comment Share on other sites More sharing options...
silvermate Posted February 23, 2005 Share Posted February 23, 2005 i was just refering to the bushings alone........not any other components......they are "relatively" inexpensive..... BTW, you do not need a machine shop to press them in.......there are many ways to DIY the bushings in and out..........ie......cut, heat to get them out.......you can use a rigid C-clamp or equivelant and plenty of grease to press them in its just amounts to how much time and or money you have, and/or willing to spend Quote Link to comment Share on other sites More sharing options...
cruznroadking Posted February 23, 2005 Share Posted February 23, 2005 I had a 90 LS with similiar squeaks & it turned out to be front sway bar bushings,which were really inexpensive. I tried lubing them first but the noise came back. Replacing them took care of the problem. Car had 95k on it then. Quote Link to comment Share on other sites More sharing options...
lexus400 Posted February 24, 2005 Share Posted February 24, 2005 Yeah, I second that. Do the sway bar bushings first. They're cheap and easy and pretty good chance that's your squeak. Bob Quote Link to comment Share on other sites More sharing options...
