majkmil Posted February 21, 2005 Share Posted February 21, 2005 Hello, I need to have my rotors resurfaced or replaced. I have a pretty good shake when braking at higher speeds. I have instructions from TIS that says I have to remove pads to remove the calipers. The dealer says the pads are fine. Has anyone removed calipers on 98-00 LS, And if so do you HAVE to remove the pads first? Thanks Mark Quote Link to comment Share on other sites More sharing options...
Watisgood Posted February 21, 2005 Share Posted February 21, 2005 http://www.lexls.com/tutorials.html Hope that can help you out in the mean time -Jay Quote Link to comment Share on other sites More sharing options...
majkmil Posted February 21, 2005 Author Share Posted February 21, 2005 Checked that first, those are on a first gen LS. They are very different, but thank you. You don't have to remove the caliper to replace pads on a 98 LS. Anyone else? Quote Link to comment Share on other sites More sharing options...
jadecuir Posted February 21, 2005 Share Posted February 21, 2005 Checked that first, those are on a first gen LS. They are very different, but thank you. You don't have to remove the caliper to replace pads on a 98 LS. Anyone else? ← I don't know about '98 model, but most all the cars I've worked on do NOT require pad removal to change the rotors. That's what you want to do , right? You should have to remove the Caliper Assembly, with the pads in place, and change the rotors. You may have to compress the piston side a little to slide it back over a new rotor, but a turned, used rotor should be a breeze. If your rotors are near undersize, you might consider buying a new set, as a warped rotor may take quite a bit of machining to clean up. You could spend anywhere from $10 to $25 dollars apiece to turn a rotor down to minimum thickness, and it won't last very long. They tend to overheat when they get thin. Look on ebay. I just replaced all four rotors on my '90 LS for $120. And the rotors I bought are drilled, slotted and zinc plated. If all you need are the fronts, You could probably pick up a pair for $50 to $70, plus shipping. There are dozens of vendors selling all types, so shop around. You can spend twice to three times that amount for Brembo or some other brand name, but I don't think that's necessary. Rotors are pretty simple to make. John D Quote Link to comment Share on other sites More sharing options...
majkmil Posted February 21, 2005 Author Share Posted February 21, 2005 Thank you. I did'nt think I had to remove the pads. Are there any manf. you recommend or ones I should stay away from. I would like to stay oem bit they are over a hundred $ for one side. Have the rotors changed over the years? Quote Link to comment Share on other sites More sharing options...
92Lex Posted February 21, 2005 Share Posted February 21, 2005 If you are going to replace the rotor, you might as well replace the pads at the same time. If the rotors are warped there's a good chance those pads aren't so flat either. Quote Link to comment Share on other sites More sharing options...
Lexls Posted February 21, 2005 Share Posted February 21, 2005 The instructions on my site should help you. The procedure is similar for 98-00 LS's. If you're going to buy pads, get the OEM ones. Front: These are different, 4 pistons. You can replace the pads without removing the caliper. However, you need to remove the pads and caliper to remove the rotor. The pads may be able to stay in the caliper assembly when it is removed. Rear: Pretty much exactly the same as first gen. Quote Link to comment Share on other sites More sharing options...
cruznroadking Posted February 21, 2005 Share Posted February 21, 2005 I believe that there are brake pad warning sensors on the calipers that need to be inspected & possibly replaced if they are worn. Quote Link to comment Share on other sites More sharing options...
silvermate Posted February 21, 2005 Share Posted February 21, 2005 if you need new rotors, you might as well go with the drilled/slotted.....better performance, cooler brake temp.......and they look cool they are very reasonable on price which is a plus of course you will need new pads to go along with them as well. Quote Link to comment Share on other sites More sharing options...
