boss of tokyo Posted February 15, 2005 Share Posted February 15, 2005 Hi Im due to getting a 1995(1991-1997) JDM Windom 2.5 V6 24v soon & wondering if this Windom 2.5 engine was the same as the 1988 (1987-1991)Toyota Camry 2.5 V6 24v engine? If so it make it easier to source parts when needed in future. I know the 1989 Camry 2.5V6 24v is similer to the 1989 Lexus ES250 but when the Es250 got replaced in 1991 by the ES300 was there also a 2.5V6 available in the US or just the 3.0? I know in Japan the 1991 onwards ES300(called Windom there) had 2 engines choices - a 2.5V6(which im getting soon) & a 3.0v6 Thanks Quote Link to comment Share on other sites More sharing options...
vcv10guy Posted February 15, 2005 Share Posted February 15, 2005 When the ES300 came out the only engine available was the 3.0 litre V6 3VZ-FE. In 1994 it became the 1MZ-FE. The ES250 for the U.S. has the 2VZ-FE. Is that the engine your Windom/ES has? If your future car has that engine in it then parts from the ES250/Camry V6 will be interchangable. Quote Link to comment Share on other sites More sharing options...
xxxavier2k Posted February 15, 2005 Share Posted February 15, 2005 This is my info on a 1994 25g windom: Chassis: VCV11 Displacement, cc 2496 Engine model 4VZ-FE Max.power (Net), kw(PS)/rpm 175 ps (128.71 kw) / 6000 rpm Max.torque(Net), N*m(kg*m)/rpm 22.8 kg*m (223.59 N*m) / 4800 rpm Power density 8.63 Engine type V type 6 cylinder DOHC24 valve Hope it helps Quote Link to comment Share on other sites More sharing options...
