You get codes on my 1993 by pressing recirc and auto buttons and turning on key.
There is also info on jumping TE1 and E1 of the datal link connector and counting flashes on the check engine light.
Do both of these give the same data, if so why wouldn't you just always use the reciir/auto readout?
Figured it out, AC codes
Under hood jump the T E1 and E1 of the diagnosis and counting flashes on the check engine light for engine codes.
got code 25 and 26 as my problem
glad you did
i was about to tell you that you were diagniosing your hvac system
Is there a code list somewhere on the site? I recently had to reset the airbag light, after removing the instrument cluster to replace the heater core.
Thanks
Sonny
