gijones Posted January 20, 2005 Posted January 20, 2005 Need your help. The clock resets to 0100 am and I have already recharged the battery. Any ideas??????:cries:
Russ White Posted January 21, 2005 Posted January 21, 2005 My idea would be to have the battery load tested. I suspect a defective or worn out battery. Good luck. Russ
SKperformance Posted January 21, 2005 Posted January 21, 2005 if you had searched it would suggest to change your battery as it si common for your problem
mikey00 Posted January 21, 2005 Posted January 21, 2005 Need your help. The clock resets to 0100 am and I have already recharged the battery. Any ideas??????:cries: ← Here is more info then you will ever want to know. http://us.lexusownersclub.com/forums/index...=16728&hl=clock
gijones Posted January 21, 2005 Author Posted January 21, 2005 My idea would be to have the battery load tested. I suspect a defective or worn out battery.Good luck. Russ ← Thanks for the response.
gijones Posted January 21, 2005 Author Posted January 21, 2005 if you had searched it would suggest to change your battery as it si common for your problem ← Thanks very much, indeed it seems like a limited life for the battery considering it's been almost six years.
gijones Posted January 22, 2005 Author Posted January 22, 2005 Hey everyone, problem resolved. It seems that the digital clock reset becomes an early warning sign that the battery will eventually die (this one lasted over 5 years). Thanks everyone B)
