lexus400 Posted January 6, 2005 Share Posted January 6, 2005 I've been trying to get my belt on for about two hours... I have the cams and crank where they need to be but no matter what I do one (just one) of the marks on the belt is off one tooth ? Won't the tensioner make up the diff or does it need to be exact ? Also, can someone clarify the belt routing ? What the manual calls left and right seem to be the opposite of what I'm thinking. Is the rear/back (near the firewall) cam pulley the last thing I put the belt on or is it the front one ? Don't know if that makes a difference in my belt marks. I did check and I have it facing the right way. thanks, Bob Quote Link to comment Share on other sites More sharing options...
sunman Posted January 6, 2005 Share Posted January 6, 2005 as long as the slack is near the tensioner, it should be fine. If the slack is between 2 pullies, then you're in trouble. Quote Link to comment Share on other sites More sharing options...
