cpr_carpenter Posted January 3, 2005 Share Posted January 3, 2005 Members, I just bought my 1st Lexus, a 2001 GS430 31K miles. Awesome! It's pretty powerfull, however, what is correct or best way to get the rated 5.8second 0-60. From a dead stop I basically floor it. With timer on my watch I get around 7.5sec. I would have expected the tire to burn out or at least squeal. The ECT in in power mode, shifter in D position. Am I suppose to hold the break with left foot and rev up the engine before releasing brake? I'm not a racer so parden my ignorance.... thx Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted January 3, 2005 Share Posted January 3, 2005 Most of those #'s are derived from professional drivers on a closed track. Probably results you and I could'nt attain without some time at the track. B) Quote Link to comment Share on other sites More sharing options...
bartkat Posted January 3, 2005 Share Posted January 3, 2005 Members,I just bought my 1st Lexus, a 2001 GS430 31K miles. Awesome! It's pretty powerfull, however, what is correct or best way to get the rated 5.8second 0-60. From a dead stop I basically floor it. With timer on my watch I get around 7.5sec. I would have expected the tire to burn out or at least squeal. The ECT in in power mode, shifter in D position. Am I suppose to hold the break with left foot and rev up the engine before releasing brake? I'm not a racer so parden my ignorance.... thx ← It usually doesn't make that much difference. It's really hard to time with a watch. Turn your "trac" off and try it that way. Quote Link to comment Share on other sites More sharing options...
MarkW Posted January 3, 2005 Share Posted January 3, 2005 Members,I just bought my 1st Lexus, a 2001 GS430 31K miles. Awesome! It's pretty powerfull, however, what is correct or best way to get the rated 5.8second 0-60. From a dead stop I basically floor it. With timer on my watch I get around 7.5sec. I would have expected the tire to burn out or at least squeal. The ECT in in power mode, shifter in D position. Am I suppose to hold the break with left foot and rev up the engine before releasing brake? I'm not a racer so parden my ignorance.... thx ← Dude I have only one thing to say. SRT intake and PC upgrade, and hold on! Quote Link to comment Share on other sites More sharing options...
Neo Posted January 3, 2005 Share Posted January 3, 2005 Members,I just bought my 1st Lexus, a 2001 GS430 31K miles. Awesome! It's pretty powerfull, however, what is correct or best way to get the rated 5.8second 0-60. From a dead stop I basically floor it. With timer on my watch I get around 7.5sec. I would have expected the tire to burn out or at least squeal. The ECT in in power mode, shifter in D position. Am I suppose to hold the break with left foot and rev up the engine before releasing brake? I'm not a racer so parden my ignorance.... thx ← Dude I have only one thing to say. SRT intake and PC upgrade, and hold on! ← Just wondering, PC? Quote Link to comment Share on other sites More sharing options...
Vette Boy Posted January 3, 2005 Share Posted January 3, 2005 ...From a dead stop I basically floor it. ← To get a good launch without spinning the tires: At a complete stop, brake hard and load the TC up by reving the engine to ~1500 RPM (right under the stall speed of the TC). If you have to much gas, the rear wheels will start breaking loose, back off slightly. At the same time, release the brake w/left foot and roll into the throttle w/right foot. This is the part that takes skill. If the throttle is just mashed, then the tires will spin and the time will suffer, if it's not rolled into fast enough, the max performance isn't realized. Quote Link to comment Share on other sites More sharing options...
cpr_carpenter Posted January 4, 2005 Author Share Posted January 4, 2005 VetteBoy, Thanks for instruction, I'll have to practice that. I'll also try it with the VSC off too. BTW, what do you mean by TC (obviously not tubro charger) I'll also look at the SRT intake option Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted January 4, 2005 Share Posted January 4, 2005 VetteBoy, Thanks for instruction, I'll have to practice that. I'll also try it with the VSC off too. BTW, what do you mean by TC (obviously not tubro charger) I'll also look at the SRT intake option ← TORQUE CONVERTER Quote Link to comment Share on other sites More sharing options...
mbald93 Posted January 4, 2005 Share Posted January 4, 2005 Members,I just bought my 1st Lexus, a 2001 GS430 31K miles. Awesome! It's pretty powerfull, however, what is correct or best way to get the rated 5.8second 0-60. From a dead stop I basically floor it. With timer on my watch I get around 7.5sec. I would have expected the tire to burn out or at least squeal. The ECT in in power mode, shifter in D position. Am I suppose to hold the break with left foot and rev up the engine before releasing brake? I'm not a racer so parden my ignorance.... thx ← It usually doesn't make that much difference. It's really hard to time with a watch. Turn your "trac" off and try it that way. ← whats srt and pc upgrade how much and where. Quote Link to comment Share on other sites More sharing options...
Vette Boy Posted January 4, 2005 Share Posted January 4, 2005 ...I'll also try it with the VSC off too. BTW, what do you mean by TC... ← Yes, to get the best times, you'll need to be PWR mode with VSC off. As noted, TC is torque converter. It's the clutch of an auto trans. By loading it up to the stall speed you eliminate any delay in spooling up the drivetrain. With a little practice, you'll max out the number, whatever that is. Meeting magazine nunbers on an auto trans is much easier that a manual. I've been able to max out my old Imapala SS with auto trans, with my manual trans Vette, I'm a 1/2 second slow in the quarter mile, after 6-7 trips to the strip. Quote Link to comment Share on other sites More sharing options...
bartkat Posted January 4, 2005 Share Posted January 4, 2005 SRT = Swift Racing Technologies http://www.swiftracing.com/ Red = Stock Blue = SRT Quote Link to comment Share on other sites More sharing options...
Vette Boy Posted January 4, 2005 Share Posted January 4, 2005 re: SRT intakes: how's that old line go, "figures don't lie, but liars figure"? Quote Link to comment Share on other sites More sharing options...
DJRLEXUS Posted January 9, 2005 Share Posted January 9, 2005 re: SRT intakes:how's that old line go, "figures don't lie, but liars figure"? ← Sorry to just jump in but I was wondering if the SRT intake with the ecu mod would void my warranty? It seems like a sure bet to extract a little extra power and response. Thanks, Quote Link to comment Share on other sites More sharing options...
