I use directions from http://www.intellexual.net/faq.html
to convert cornering lights to fog lights on my 92' right now in garage. They mentioned H3 as lights. I bought sweet ones (blue) on eBay. But they don't fit... the stock light is 1156 27W. I will do the relay into 55W. What lights to I use with the same wattage and that they will fit into the housing?
Has anyone done this conversion? I'm in garage right now!! Help!!!
Just go out to maybe pepboys or local rice shop and grab some 1156 white lights.  Simple.
but they are 27w lamps... the instructions say that the power will be supplied will be 55w, right?
if the wattage will be supplied the same, what is the point of wiring all these wires with the relay? why not supply the power from parking lights? The point was (if I didn't miss it) to wire to 55W, so the lamps will be brighter and lights will be used as fog lights...
i'm lost now... 31 looked at this posting and only one person had something to reply on it... :blink: :chairshot: :cries: :censored::unsure:
