rich21 Posted December 9, 2004 Share Posted December 9, 2004 how can you rewire the foglights so that they turn on with the headlight and stay on not just only when you use your turn signals? Quote Link to comment Share on other sites More sharing options...
Mungrin Posted December 9, 2004 Share Posted December 9, 2004 how can you rewire the foglights so that they turn on with the headlight and stay on not just only when you use your turn signals? ← those are not foglights,they are turning light and i am still trying to figure out how to wire them to stay on when my lights are on but no one will tell me either :cries: Quote Link to comment Share on other sites More sharing options...
SC4Million Posted December 9, 2004 Share Posted December 9, 2004 ok, They are not foglights but turning lights and making them work as foglights will be purely cosmetic because they A. are not very bright. and B. are pointed the wrong way. But you know this right? so to answer you question, I think this is the solution you need. http://www.intellexual.net/faq.html#091 Quote Link to comment Share on other sites More sharing options...
rich21 Posted December 11, 2004 Author Share Posted December 11, 2004 is there anybody in south jersey that can do it. ill pay them Quote Link to comment Share on other sites More sharing options...
sergioon20 Posted January 23, 2005 Share Posted January 23, 2005 how can you rewire the foglights so that they turn on with the headlight and stay on not just only when you use your turn signals? ← super easy my friend. u will need:a 20 amp fuse, wire and a relay. step 1- dissconnect your fog lamps from the car . step 2- cut the plug off of the factory wires and tape them off. u wont use these anymore. that plug put back into the bulb. step 3- find out which one is pos and neg[ red + , black is ground]on the bulb. step 4- the relay you need to get is a uneversal 5 pin relay. any part store will have them. i want u to wire the relay like this 30- this will go to the batterys pos [+] side. u need to put a 20amp fuse no more than 3 inches from your battery connection. 87a- nothing leave it alone. 87- this will be where u hook the pos[+] side of your for lights to 86- ground. u can put this to the battery neg.[-] side 85- connect this wire to a parking light or headlight wire that has pos[+] 12v. if u hook this up to your parking or sidemarker lights, the fogs will come on with them. If u choose to hook it up to the headlamps, they wont come on till the headlights are on. last dont forget to ground ur fog lamps. that should be the other wire in the plug for those foglights at the bulb itself. u can take it to the batterys ground[-] side. just make that wire short as possible. My name is Sergio and i own a car audio install shop, but we major in electrial issues and fog lamp installation. If u still need help [which is perfectly ok] u can call me @ 216-376-4515 Quote Link to comment Share on other sites More sharing options...
