LexusChicago Posted November 30, 2004 Share Posted November 30, 2004 I have a 93 GS300 with 195,000 miles. I bought it at an auction with 180,000 in April for $4,000. The car is incredible. Smooth as can be! Before that I had a V6 Camry for 7 years. Bought that with 34,000 miles and lost it in an accident with 212,000 miles. Toyota really is the best. I had Lexus run the VIN# to see what maintenance was done to the car. No information after 60,000 miles. I assume that the timing belt was replaced once and that I need to do it again. How do I know I need to replace it? What signs should I look for? Should I change the water pump at same time? Is there a tension belt as well? Just being proactive. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted November 30, 2004 Share Posted November 30, 2004 I have a 93 GS300 with 195,000 miles. I bought it at an auction with 180,000 in April for $4,000. The car is incredible. Smooth as can be! Before that I had a V6 Camry for 7 years. Bought that with 34,000 miles and lost it in an accident with 212,000 miles. Toyota really is the best.I had Lexus run the VIN# to see what maintenance was done to the car. No information after 60,000 miles. I assume that the timing belt was replaced once and that I need to do it again. How do I know I need to replace it? What signs should I look for? Should I change the water pump at same time? Is there a tension belt as well? Just being proactive. Thanks in advance. ← YES TO ALL your questions, except NEVER ASSUME!!! You know what happens when you !Removed! u me Quote Link to comment Share on other sites More sharing options...
bartkat Posted November 30, 2004 Share Posted November 30, 2004 http://us.lexusownersclub.com/forums/index...?act=Search&f=1 Quote Link to comment Share on other sites More sharing options...
