my battry incator light keep coming on from time to time, so I went to Sears to have it check out
becouse I had pucher my battry from them about 16 mo. early. They replace the bettry with a new
Die Hard, but the light still come on most of the time, do any one have any suggestion?
Check connections, positive and negative main cables for corrosion, chassis ground, alternator connections and alternator grounds. It won't hurt to have your alternator tested.
exactly get that all checked
the light doens't mean there is a problem with the battery it means a problem with the charging system
I had a leak under my distributer and it was dripping oil on the alternator. Battery light came on from time to time untill my alternator completely died. Get it checked out because its expensive.
yah from what i have read the power steeing leak would do that alot and cause more problems and money later
