Steph3235 Posted Monday at 06:31 PM Share Posted Monday at 06:31 PM I got 93 sc300 changed fuel pump an cleaned. Old gas out gave. It. Tune. Up plugs. An. Wires. An still won't. Start. Gas. Not. Reaching. Engine . Any suggestions Quote Link to comment Share on other sites More sharing options...
craw Posted Tuesday at 12:30 AM Share Posted Tuesday at 12:30 AM How dirty was the tank? Is there sediment in the lines? Quote Link to comment Share on other sites More sharing options...
Steph3235 Posted Tuesday at 12:35 AM Author Share Posted Tuesday at 12:35 AM Tank had ol. Black gas was sitting a while. Drained lines. At bottom of tank put all back together clean. With. New. Filter. Gonna. Try ecm next take it off?? Quote Link to comment Share on other sites More sharing options...
craw Posted Tuesday at 12:41 AM Share Posted Tuesday at 12:41 AM Can you hear the pump running? Are all the fuses good? The ecm is probably a good bet or a broken wire somewhere Quote Link to comment Share on other sites More sharing options...
Steph3235 Posted Tuesday at 12:46 AM Author Share Posted Tuesday at 12:46 AM Pump food. Fuse. Will check. Again. But. Think. It's. Good. Ecm. My. Last. Resort? I. Think?? Quote Link to comment Share on other sites More sharing options...
craw Posted Tuesday at 12:53 AM Share Posted Tuesday at 12:53 AM The reason i asked if you could hear the pump is because when i power up my car i can hear the pump. So can you hear it pressurizing? Also dont forget the relays if it has one Quote Link to comment Share on other sites More sharing options...
