Ebrake Light On In Dash
Mungrin
The ebrake light on my dash comes on when i first drive my car in the day then goes away.Could it mean that there is air in the line or something?All the pads on my car are like new.I did a search but all i found was that maybe the pads need changing but im sure my pads are good.Any help would be great.thx.
mine did that because my break fluid was getting low.  Might check that.
i can almost garuntee that you have the same problem as me, a short in the ebrake handle sensor. the next time the light is on, pull the handle up (not quite to thew first click) and drop it back down, ill bet it goes out.
That's probably correct, or the switch and lever aren't making phsycal contact.
