Sunroof rebuild?
sluried
hey guys i had just bought a 1990 lexus ls400 in december of last year. My sunroof has never been able to fully open and it had just started to leak recently. The motor itself is fine so I took the sunroof glass off and i found that a lot of the plastic is brittle or just broken. Im just wanting to know if there is some kit out there that has all these parts so that i could just replace everything?
Most likely there are no repair kits available for a 34 year old car.  However, there still might be OEM parts still available but it's going to be hit/miss.
Here's a link to a Lexus dealership in CA that I use, showing the sunroof for a 1990 LS.  Scroll down below the diagram to the parts list; there are some parts that "might" be still available.  Inquire before ordering parts.  YOur local Lexus dealer should have access to the same diagrams/parts lists.
https://parts.lexusofpleasanton.com/a/Lexus_1990_LS-400/_65510_6729510/ROOF-PANEL--BACK-WINDOW-GLASS/431410-6104.html?assemblySearchGuid=736FCD75-853D-40A0-A65F-77FB025C8147
Having the OEM part number will allow you to search for any parts you may need.  Here are a few part search sites that I have used.  I will admit that for old car parts, success has been very limited. FWIW, the dealer ship in the above link uses Parts Voice.
https://www.partsvoice.com/
https://www.rearcounter.com/
You can also search outside of the US thru Amayama.
https://www.amayama.com/en
There's always the pick-and-Pull yards, but used parts are sometimes more worn than what you're trying to replace.
