tmitch3 Posted July 9 Share Posted July 9 just replaced both exhaust manifolds on my 09 GX470. a couple of days later it threw me a PO333 code with a C1201 code. these sensors are wearing me out. as long as it stays out of creepy crawler mode, it runs fine. but these blasted sensors are driving me crazy. i don't see much info on anyone else having sensor issues. Quote Link to comment Share on other sites More sharing options...
RX400h Posted July 9 Share Posted July 9 Quote Let’s break down the codes you’re encountering: P0333 Code (Knock Sensor 2 Circuit High Input, Bank 2): This code indicates that the input voltage from a knock sensor circuit in one of the cylinders on bank 2 is higher than the manufacturer’s limit. Knock sensors detect unusual engine noise caused by incorrect air-to-fuel ratios, which can lead to detonation and cylinder damage. Possible causes: Faulty knock sensor (especially if the engine runs quietly) Corroded connectors Frayed wiring Broken sensor during starter replacement. Replacing the knock sensor usually resolves this issue. C1201 Code (Toyota Engine Control System Malfunction): The C1201 code triggers when the engine control system malfunctions. It can be caused by various factors, including a loose or defective gas tank cap or a faulty oxygen sensor. Remember to check the knock sensor wiring and connectors first, as other engine codes might be contributing to the issue. If you need further assistance, consider consulting a mechanic to diagnose and address the problem effectively. Quote Link to comment Share on other sites More sharing options...
