I am trying to remove the headlamp/headlight housing from my 2001 RX300
I removed the 2 screws under the wheel liner but it will will come out, its it looser however appears something is holding the top of the light?
any clues?
its the driver headlamp
thanks Marc
Two, three(??) more screws "in the clear" if you look carefully around the exposed top of the assembly. One of the screws also holds the bottom grille piece in place.
  • 2 months later...
and after you find all of the screws hiding on the top, if it still doesnt easiely come off, pull! There is also a clip that holds it clolser to the car
