TYDOG3333 Posted December 3, 2023 Share Posted December 3, 2023 Hi, i have a 2000 ls 400, the solenoids clip where the wiring harness plugs into it at has broken completely off the solenoid. Is there any hope in repairing this? Also what size o rings dos the solenoid take? I am trying to avoid having to replace the whole rack! Quote Link to comment Share on other sites More sharing options...
RX400h Posted December 4, 2023 Share Posted December 4, 2023 The o-rings are typically specified by inside diameter and cross-section diameter, most likely in millimeters. You will need calipers or an o-ring size cone. Have you verified that this component is or is not available, separately? Quote Link to comment Share on other sites More sharing options...
