Crank But No Start - No Spark
I Have 2008 LS460- I Have Crank But No Start .I Found Vehicle To No Spark Triggering . Check For DTC’s Retrieved 1 Code P0353- Ign. Coil C Circuit Malfunction
Checked For proper Voltages And Grounds Found No Fault , Verified No ECM Control , No Triggering . Do I Have A Bad ECM Or Bad Crank Position Sensor . Found No Codes Indicating CPK Malfunction? Customer Had Other Mechanics Attempt To Diagnose The Problem .Already Spent A Bunch Of Money And Still No Running Vehicle . Bottom I Working With A Budget .Should I Take The Chance And install A New CPK Before Telling These People They A ECM At $1200.00 Used .
Thank You
