Electronic Steering Column Problem..
I had the same problem. You will have to remove the plastic covers behind the steering wheel, there is a plastic wheel, the teeth on that wheel are probably stripped or worn out. In my case, I had to adjust the wheel a little and my problem was solved.
  • 4 months later...
