Need some opinions on which choice you would go for and why....
1. HKS Hypermax II
2. TEIN Type flex with EDFC (Electronic Damping Force Controller)
3. JIC FLT-A2
All three can be found here....
Soarer Coilovers
Thanks
i would go with the teins #1 reason is because if you get the edfc you can change dampening from inside the car. and another reason is that the hks and jic can ggo out easier if you hit a big pothole, more than the teins.
teins arent really up there with JIC or HKS. but they all do the same thing so it doesnt really matter. I'd probably suggest the Tein flex of the JIC, HKS if want some hardcore stiffness for any type of racing.
Unless youre going to be doing racing or something where you will actually need to change your ride height and spring rate often, just get a good set of adjustable struts and good springs. Itll save you about $1k easy
Thanks for the replies guys....
I have gone ahead and bought the JIC FLT-A2 Kit, I should have them fitted sometime in the next 10-15 days ;)
