Silvertone Lights
lovlex
u mean silverstar? they are a great alternative to PIAA hyperwhites if you dont want to spend the extra money. They are pure white with a little hint of blue. i like the way silverstars look. I say get them, they make a HUGE difference on the SC. make sure you get the low beams and fog lights.
For budget considerations, replace the low beams first as they are easy to access and replace with just a few minutes effort. Purchase the high beam model of the bulb (does not have cap on tip of bulb and is rated 10 watts higher). Cut or file off the two tiny ribs where the assembly plugs into the harness plug.
Your low beams will now look GREAT -- one of the easiest, cost effective and best results of any lighting modification you can make.
The high beams as they are may look OK to you -- you can decide after you do the low beams if you want to upgrade the high beams with Silver Stars as well. You'll use the same model bulb for both the low and high beams. You just will not have to modify the connector on the high beams -- plug and play.
Or you can replace the fog lights with the appropriate Silver Star bulb in lieu of high beams for budget purposes.
If money not an issue -- replace them all with Silver Stars.
