Power Seat Problem
rayder34
did the programming part work in the past?
are you programming them the correct way?
did anything spill on switch?
is the switch hook up or maybe the wire the goes to/from the switch is broken or cracked?
have you removed the switch and looked at it or tested it?
I ask all of these questions because your question is not a new one and the resolution to previous questions has been something that I asked.
steviej
