Burn Too Much Fuel...
cashmoney
What is the problem with the O2 sensor?
If your O2 sensor has a problem, then the ECU may be running the engine rich to prevent a lean condition. This would cause poor gas mileage. Maybe try resetting the ECU by disconnecting the negative battery terminal for 30 minutes and then reconnecting.
My O2 sensor is expired......the Company tell me have to change New Sensore..
and last 2 weeks i have just change the NGK Iridium Spark Plugs...
i'll take off the Battery tonight then connect tomorrow....
