Infiniti Speakers
timmay217
i'm planning on getting a pair of Infinity Kappa 63.5i for the fronts but the rms is rated at 75 rms.....i know for sure that the stock amp will not be able to pull it but will it still sound ok or should i just go with something else?
Read the FAQ.
Bottom line is that I wouldn't mess with the audio unless you're really sure of what you're doing. It's not that expensive to have professionals help you select, install, and adjust speakers.
If you do it on your own without the proper adjustment equipment, you're just as likely to get WORSE sound as better.
In general, I like Infinity speakers (just bought a new set of towers at home and used all Infinity the last time I upgraded a car stereo), but would never simply yank factory speakers and replace them with Infinity and expect them to sound good. At a MINIMUM, you'd want a good parametric equalizer to adjust the sound to match the car interior.
