Sc400 20" Wheels No Rub
sc400atl
The best sizes depend on how you want your coupe to look. You can go 20x8.5 and use a 245/35/20 tire and be fine. You could also go with a 20x10 rear with a 275/30/20 tire for the staggered look. www.rpmsuperstore.com
I'm shopping for some 20" rims for my sc 400. I heard if I dont get the right size and fit (+offset) it will rub. What is the best 20" size wheel and tire specifications for the sc400?
I'm using 20x9 rims on my 92' SC400 with 245/35/20 all around with no problems, but I also replaced my upper and lower rubber control arm bushings to Daizen polyurethane bushings.
