Erik Posted September 20, 2004 Posted September 20, 2004 If i install a cold air intake for my IS 300 do i need to anything else to the engine? will there be too much cold air in it? I dont really work up my car i just want more horse power
SKperformance Posted September 20, 2004 Posted September 20, 2004 You have to use premium gas from now on. I think their is something to be done or the cel comes on, i can;t remeber what it is ,see what a search shows up.
Nd4spd Posted November 12, 2004 Posted November 12, 2004 You have to use premium gas from now on.I think their is something to be done or the cel comes on, i can;t remeber what it is ,see what a search shows up. ← why would u have to use premium gas?
SKperformance Posted November 13, 2004 Posted November 13, 2004 You are ingesting more air to the almost same amount of fuel thus causing a lean situation.
bartkat Posted November 13, 2004 Posted November 13, 2004 I don't think there is a true CAI for the IS300. There are various intakes on the market. You gotta make sure the filter has a "heat shield" with it or turbulence from the cooling fans will caus stalling at idle and low speeds. Some intakes will give a CEL because the MAF gets a different reading. Sometimes you can cure that via a ECU reset. The best bang for the buck is a JoeZ intake tube with a TRD replacement filter. Get's you about 8 HP. Total cost about $175 and the TRD is a Toyota part. For the most power, the SRT intake with piggyback ECU is tops. But with that one, you have to make some solder connections into your stock ECU, and the inakes cost around $500. http://www.swiftracing.com/ PS. You should already be running premium fuel in your IS300.
