Hot Side Panel Front On '99 Gs300
I've got a strange one and am not sure whether it is a problem. The front side panel around the wheel on the driver's side really gets hot, even after a short / 10 min ride. As soon as I noticed it I checked some other GS300's and noticed some temperature increase in the same location. Does anybody know what's going on?
Thanks!
It's the outside metal panel just above the front wheel on the steering side. Not sure when it started. Have no issues with brakes that I am aware of. No Noises. No work has been done recently. Indeed, it makes sense to suspect the brakes as this is right above the brake. I did not notice a higher temp on the other side.
The other day I walked around a parking lot with several GS300 cars and the majority had a elevated temp on that spot??
