My driverside headlight had moisture in it so on friday i clear cornered both of my headlights and resealed them with silicon, the passenger side is fine, but the moisture came back on the driverside!!!! Does anybody have any suggestions as to were the moisture is getting in from???? :angry:
take the assembly out, hold it lens down in a tray of water (just over the siliconed area). see if any water seeps in.
The other possibility is moisture is getting in around where the bulb is inserted. Check to see if the gasket on the bulb connector is intact.
steviej
