Audio
Travieso~13
Does anyone have any suggestions as to a where i can run the power cable back to the amplifier? I'm hooking up an amp w/a sub to my '92 LS, but i cant find a place under the hood where to pass the power cable into the cabin. This car is very sealed up.
Has anyone had this problem?
What was your solution?
Any suggestions might help Thanks!!!
Steve
There is a grommet under the driver's side foot area. This is the closest place you can run power without having to drill through the firewall. I ran my power through the firewall, but only because there was a hole there from my alarm install :)
Is it under the carpet? Would it go under the car, out the firewall? Or is it behind the pedals? Also i saw there is a button under the gas pedal, what does that do, can i run it trhough there? (would you happen to have any pics?)
Thanks for your help
