wayne Posted May 19, 2003 Posted May 19, 2003 i have a 2002 ls430 with 26000 miles on ....original warrranty expires 9/05 should i look at buying an extended warranty as i will probably have over 50000 by then.. what are some good guidelines to consider if buying an extended lexus warranty
gslx4s Posted May 21, 2003 Posted May 21, 2003 i have a 2002 ls430 with 26000 miles on ....original warrranty expires 9/05should i look at buying an extended warranty as i will probably have over 50000 by then.. what are some good guidelines to consider if buying an extended lexus warranty Personaly, i do not think you will need it. Most people change cars with in five years. If you think you woould have it longer then that, then it may be a good idea to get the warranty. Also if you up your services you should not have any problems.
SKperformance Posted May 21, 2003 Posted May 21, 2003 more related to the ls or maintance section than detailing but i agree do the maintance and the car will run like clock work i really wanted to have an extended warr when i bought my 94 es in 97 but have had no need for it except for a few small things i was just worried of overall costs as i had a GM grand prix before which i was always fixing something
SW03ES Posted May 21, 2003 Posted May 21, 2003 Naa, skip the warranty, the car is so flawless mechanically that anything big you could probably get Lexus to pay for out of warranty anyways.
