How To Tighten Pulley Belt?
spoonfed
i have an 91 ls400 and i've kinda hand pushed on the belts and it feels a lil loose and when i gas it a liittle faster it sounds like its slipping a tiny bit, i was wondering where the adjuster for is it, so i got an idea where to look for, i can't see anything from up top. thanks!
yeah of course. just pull ur hand and check for the tenstioner, this is the part you are able to move, you can tighten it with the wrench.
I always thought a tensioner was 'self tightening'; suggest that you install a new belt; if that doesn't work you will have to install a new tensioner. If you think you have grease/oil on the pulleys, you may want to spray them with brake cleaner first.
