Vanity Light
Hello. I have a 93 SC that has a vanity light(visor light) that stays on even with the cars turned off. How do I fix the problem? I noticed it few hours ago.
Another thing, the driver side's light hasn't worked since I got the car 4 years ago. How do you change the bulb? What kind of bulb is it? Thanks.
Fobster,To change the bulb there is a small slit on the bottom of the plastic lens. Use a small flat head screw drive to open the plastic lens. As far as the bulb size I'm not sure(not listed in car manual)? Just take the bulb with you to the auto store and try to match with another similar bulb. Good Luck!
