honkand Posted July 12, 2004 Posted July 12, 2004 I have a 93 ES300 with a Pioneer sound system, the CD Deck is in the trunk. A cartridge was loaded, but the Audio display showed (i.e. nothing) indicating that the deck was empty. I knew that the CD cartridge was loaded. When I tried, the CD deck wouldn't eject, I suspected that the OPEN button had failed. I did a continuity test, like the manual suggests, and the OPEN switch was bad. I left the CD deck unplugged for the night. Started the car, the radio is completely dead now. Replugged the CD deck in but still dead. Anyone now where I can get the CD deck repaired? Help!
steviej Posted July 12, 2004 Posted July 12, 2004 did you check your fuses yet? I am not totally sure, but there is a reset button on the CD deck, is there not? steviej
honkand Posted July 19, 2004 Author Posted July 19, 2004 Checked fuses, both are good. Tried reset button on CD deck, no effect. Radio still dead, won't power on.\
LexES 300 Posted April 23, 2008 Posted April 23, 2008 i've got the same problem.. any luck?? trying to install new deck and theres no power coming to the deck.. checked fuses..
