BlurrySC300 Posted June 28, 2004 Posted June 28, 2004 I've been thinking alot about people who do the 2JZ-GTE swap out in their IS. A single turbo set up seems more efficient, but why do a 2JZ-GTE swap out and then change to single big turbo....why not just turbo an IS300 and do a 6speed conversion? But thats just thoughts and also beside the point....my real question is, if you do a 6 speed conversion to a N/A IS300, will there be that much acceleration gained? If yes, any clue as to what the procedure would cost? Thanks, --John
bartkat Posted June 28, 2004 Posted June 28, 2004 If you're going with high boost, the GTE engine is stronger. If you change the trans from auto to 6 speed you might gain 0.5 seconds. You get more HP to the wheels with the 6 speed. Then, of course if you abuse it you'll start tearing up clutches and trans gears.
BlurrySC300 Posted June 28, 2004 Author Posted June 28, 2004 I'm talking about swapping a manual stock 5speed tranny for a 6speed Supra TT tranny....so would the extra gear really be worth the couple thousand dollar "upgrade"?
