Condencer Electric Fan Is Constantly On
VMF
hey ppl. got a strange problem on my ls, every time i turn the ignition on the condencer electric fan turns on. it is on even when the engine and AC is off with just the ignition on. also i have no error code from the ac sys. any ideas?
i suspect that it might be the engine coolant temp sensor or cirtquit but then why am i not gettin the error code?
i will check the sensor in 30 mins and i will let u guys know
but it might be a faulty sensor as well , not just the connection itself.:(
according to the manul if the sensor is open or short it should give me error code 14
i will check if there is a relay for that but i think it connects directly to ECU and AC ECM but i will make sure today when i will get home.
