jzz30 Posted June 16, 2004 Posted June 16, 2004 ok this all happened when i was pulling out of my driveway and got out of the car to put mail in the mail box. when i got back in my car had a rough idle and when i accelerated my tack went to zero which is funny too. my engine seems to be running either extremely rich or there is weak spark. i can smell lots of raw fuel out the exhaust and i thought the caps rotors wires and plug needed replacing. and i did but well no luck but it seems to be running smoother so i am guessing im on the right track. i am going to swap coils from my LS to see if the coils are bad. i remember one of you guys saying that you had a bad coil and had problems. and i looked at the wiring diagrams of the coil and the primary sends a signal to the tach so if thats malfunctioning than that would solve everything. any thoughts guys?
jeremyp Posted June 16, 2004 Posted June 16, 2004 Yeah, you are definitely on the right track. Tell us what happens when you swap the coils.
jzz30 Posted June 17, 2004 Author Posted June 17, 2004 just swapped coils and problem solved!. will buy coil tomorow for 75bucks at the dealer.
jzz30 Posted June 17, 2004 Author Posted June 17, 2004 oh forgot to add that it was the secondary coil right off the driver side bank above the ac.
soarer479 Posted June 18, 2004 Posted June 18, 2004 well i was gunna say fuel pressure regulator but since uve already got it solved guess not
