Mboxer511 Posted October 24, 2022 Posted October 24, 2022 Hi, this is my first time posting here. My wife has a 2012 ES350. I tried searching for the answer to my post but can only find information and instructions for the regular headlights. I would like to replace the daytime running bulbs and fog light bulbs with white LEDs so they match the headlight bulbs. Does anyone know if there is a different method to access those bulbs (different then where I would access the headlight bulbs)? Also does anyone know what the bulb type/model number is that I would need for the daytime running lights and fog lights? If anyone has any suggestions of good, white led bulbs to replace them with I would also appreciate it. I tried looking on Amazon but I'm not sure which bulbs to get. Thanks!
RX400h Posted October 25, 2022 Posted October 25, 2022 Rock auto shows this one (Phillips), which should be a good brand of bulb. The page includes an install procedure video and some tips about possibly needing a CANbus load equalizer. More Information for PHILIPS 9006 (rockauto.com) List of this and non-LED bulbs: 2012 LEXUS ES350 3.5L V6 Fog / Driving Light Bulb | RockAuto
Mboxer511 Posted October 25, 2022 Author Posted October 25, 2022 (edited) Thanks, that site was helpful. I found that the Daytime Running lights are a 9005 bulb and the Fog lights are a 9006 bulb. From that I found a white LED replacement for both of them on Amazon here: Auxbeam 9005 9006 H10 LED Fog Light Bulbs High Power 50W 3020 SMD Bulb for Fog Light, DRL, Tail lights - Xenon White 6500K (Set of 2) I found this YouTube video on how to replace the Daytime Running Lights (2008 model is the same as my 2012 model): Replace daytime running lights yourself 2008 Lexus Edited October 25, 2022 by Mboxer511
RX400h Posted October 26, 2022 Posted October 26, 2022 Great! I would recommend that you spend a bit more for a name brand, although sometimes they are multiples more expensive. When labor to replace is not trivial, higher quality is often the better choice.
