In my 94' ES, the dome light in the headliner only comes on when either of the front doors are opened never when either of the rear doors are opened. Is this normal, or do I have a problem?
the rear doors if not opened frequently the pins will seize a bit
towards the back of the door and car
there is a small rubber boot below the handle on the frame edge of the door sill
pull off the rubber boot and apply wd- 40 or preferable white grease or lithium grease
it will help reduce the friction
and the ligth should now work ok from now on
It probably is due to oxidation on the switch contacts due to lack of use. I used a spray on contact cleaner on the switch which worked very well.
Alan
skperformance, Alan, thanks for the help. I sprayed some WD 40 in there and now they work perfectly.
thanks
I'm having the same problem, but according to sk:
"there is a small rubber boot below the handle on the frame edge of the door sill
it will help reduce the friction"
I don't understand where I should apply WD-40, basically I don't understand where is the frame edge and pulling off the rubber boot part?! Please advise...
  • 10 years later...
Hi dear all sifu...
I'm new here...yes I'M having the same problem but to make things even worst my car doesn't have that rubber boot..all my door are working fine except for the driver door where the problem is giving me problem..
No rubber boot to spray the WD40
The central lock doesn't work but the front passanger is fine
Both front seat belt is very lazy to retract
Hope i can find some solution here..
Thnx n chao...
