swiggins Posted October 16, 2005 Posted October 16, 2005 Hi all. Has anyone experenced this kind of problem? When I turn on the lights, parking or full head lights, the "R' reverse indicator lights up. Shifting into reverse is normal. Now, shifting into drive the car pull away from stopped but will not up-shift. With the lights off all shifting is as normal. Thanks for the help.
chips229 Posted October 17, 2005 Posted October 17, 2005 Hi, It could be a bad earth connection somewhere on the gear lever selector,sounds like its electrical.What if you move the gear selector through the gears manually with the lights on,does it change up then?
goformike Posted October 17, 2005 Posted October 17, 2005 Sounds like the 'broken wires along the drivers side hinge in the trunk syndrome'. This is not uncommon in the gen 1 LS. Do a search for this or just look at the wires along the drivers side hinge in the trunk. You may have to unwrap the outer sheath to see the wires. You are likely to find one or more broken ones. They made them slightly too short at the factory. If any are broken, add wire to lengthen, re-wrap each one, and your problem will go away. Be sure to report back. Mike
swiggins Posted October 17, 2005 Author Posted October 17, 2005 Sounds like the 'broken wires along the drivers side hinge in the trunk syndrome'.This is not uncommon in the gen 1 LS. Do a search for this or just look at the wires along the drivers side hinge in the trunk. You may have to unwrap the outer sheath to see the wires. You are likely to find one or more broken ones. They made them slightly too short at the factory. If any are broken, add wire to lengthen, re-wrap each one, and your problem will go away. Be sure to report back. Mike ← Mike, you are so right. There were three broken wires white, yellow and black. Somehow the transmission ECU must have getting a reverse signal that prevented up-shifting. Also solved the problem of no function on the trunk realese and the bulb out indicator on the dash turned on when no bulb was out. Thanks for the in-put. And thank you Chipps as well. Sam
chips229 Posted October 18, 2005 Posted October 18, 2005 Sounds like the 'broken wires along the drivers side hinge in the trunk syndrome'.This is not uncommon in the gen 1 LS. Do a search for this or just look at the wires along the drivers side hinge in the trunk. You may have to unwrap the outer sheath to see the wires. You are likely to find one or more broken ones. They made them slightly too short at the factory. If any are broken, add wire to lengthen, re-wrap each one, and your problem will go away. Be sure to report back. Mike ← Mike, you are so right. There were three broken wires white, yellow and black. Somehow the transmission ECU must have getting a reverse signal that prevented up-shifting. Also solved the problem of no function on the trunk realese and the bulb out indicator on the dash turned on when no bulb was out. Thanks for the in-put. And thank you Chipps as well. Sam ← Glad you got the problem sorted out. These guys on here do know there stuff B) :)
Leadfoot Posted October 18, 2005 Posted October 18, 2005 Wow, that is the last place I would have ever looked for the problem. You guys do know your stuff! What a great resource for owners in despair!
leeelooo Posted October 29, 2006 Posted October 29, 2006 Your guys are Great!!!!! This thread solved my 4 probelms at once: -- 2 years ago, my Bulb-out Indicator was on every time when I 1st time press the Brake after started the car -- 6 months ago, my driver side front brake became Not Smooth; made nosie when appling brake -- last weekend, all the sudden, my trunck could not be released from release switch -- last Monday, my transmisison can not be shiffed to up gear, after i turned lights on and then got "R" After i read this, i checked my trunk hinge, YOU ARE RIGHT, there are 3 comlete broken wires, White, Yellow and White/black strip. Then after I reconnected them back all of above 4 problem fixed!!! Thanks! Your guys are Great!!!!! This thread solved my 4 probelms at once: -- 2 years ago, my Bulb-out Indicator was on every time when I 1st time press the Brake after started the car -- 6 months ago, my driver side front brake became Not Smooth; made nosie when appling brake -- last weekend, all the sudden, my trunck could not be released from release switch -- last Monday, my transmisison can not be shiffed to up gear, after i turned lights on and then got "R" After i read this, i checked my trunk hinge, YOU ARE RIGHT, there are 3 comlete broken wires, White, Yellow and White/black strip. Then after I reconnected them back all of above 4 problem fixed!!! Thanks! forgot to mentioned that my car is 93 LS400 with 129k milres...
dole2000 Posted November 1, 2006 Posted November 1, 2006 I had this happen to me on two different cars. Neither was a lexus, both where Japanese cars though. I replaced the battery cable that connect to the battery. Worth a try.
