peterjiang4648 Posted July 26, 2022 Posted July 26, 2022 2009 RX350 trouble code P0171&P0174 I used another vehicle's mass air flow sensor to replace my car's mass air flow sensor. And through the similar method I replace the B1S1&B2S1. but the long FT was still high. I have no idea about the problem. I attach the "trouble code.jpg"、“700 rpm mass air flow.JPG”、“700 rpm short FT & long FT.JPG”、“1800 rpm mass air flow.JPG”、“1800 rpm short FT & long FT.JPG”.
RX400h Posted July 26, 2022 Posted July 26, 2022 Here's an interesting read: FINALLY SOLVED! P0171 and P0174 Codes!!!! - ClubLexus - Lexus Forum Discussion
peterjiang4648 Posted July 26, 2022 Author Posted July 26, 2022 1 hour ago, RX400h said: Here's an interesting read: FINALLY SOLVED! P0171 and P0174 Codes!!!! - ClubLexus - Lexus Forum Discussion Thank you so much, I will read it carefully. 1
