bscandalous Posted May 24, 2004 Share Posted May 24, 2004 :cries: How to replace or repair the steering tilt motor for a sc400. Quote Link to comment Share on other sites More sharing options...
KellisLex Posted May 25, 2004 Share Posted May 25, 2004 suscribing, may need to do the same thing. Quote Link to comment Share on other sites More sharing options...
AWJ Posted May 25, 2004 Share Posted May 25, 2004 Give me a couple days for a procedure on that. But if you remove the shroud on the steering coloumn secured by philips screws, you will be able to see the mechanical assy and go from there. Many times, it is merely dirt and old grease that causes a failure. Remove the parts, clean them, use a quality grease and reassemble. Should work after that. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted May 28, 2004 Share Posted May 28, 2004 Bscandalous Writes: "My tilt steering is fix. I went in and added 2 washers to the gear and it worked like a charm.The Lexus dealer told me it was going to cost $792. This a easy .50 cent fix .Thanks for the info and everyone who owns a Lexus should look hear first before going to pay large sums of cash for jobs that can do yourself.Thanks again." Bscandalous: You seemed to have Reported the above post to one of us Moderators. Please don't unless you really want us to take a look at something important. thanks UCF3 Moderator SC and LS Forums Quote Link to comment Share on other sites More sharing options...
