Jimmy G Posted May 23, 2004 Share Posted May 23, 2004 I have a 1995 ES 300. When if put the car in drive and give it gas there is a bump in the front end. I tested the motor mount which I believe is broken. Does anyone have any experience changing this out. Is this somthing that I would be able to do on my own (with help from a friend) or will it require special tools? Thanks everyone, jim Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 23, 2004 Share Posted May 23, 2004 which mount upper or lower common problem i rebuild them using urethane and they last and are much stronger Quote Link to comment Share on other sites More sharing options...
rhkwon Posted May 25, 2004 Share Posted May 25, 2004 It is most definitely your motor mount. Same symptoms as mine. Replacement had it running like new. Quote Link to comment Share on other sites More sharing options...
